14 years agoCyclone II pin 76
I have build my self a really nice CycloneII dev board :cool:
The chip on the board is EP2C5T144I8N Everything is working splendidly! :D The only problem is pin 76; when I try to write this pin as an I/O, in the .qsf file, the compiler says that its cant place multiple pins to pin 76. When I look dipper the compiler say that the other assignment is nCEO how can I remove this one so pin 76 will only be I/O? (I am only using this pin as I/O) Thanks. Noam.3 Replies
I make a first board with a Cyclone 1 for a music synthesizer. I has a Cyclone, EPCS1, 50MHz osc, programming connectors and I/O connector. Then a think I can sell it for development and educational uses. So I made a motherboard with several peripheral: buttons, leds, displays, lcd, vga connector, USB-232, D/A.
Then made a second board with Cyclone II because it has more internal RAM, so NIOS will fit easier. Now I'm thinking in Cylone III. Regards. Roberto. - Altera_Forum
Thanks! worked perfectly!
Can I ask you what u used your dev board for, just out of pure hobby interest.. :) - Altera_Forum
I made my own Cyclone II dev board too, with the same chip. To solve this error, go to menu bar:
Assigments->Device->Device and pin Options go to category "Dual-Purpose Pins" and set nCEO as regular I/O pin. It will synthetize.
