19 years agoCyclone II is not working correct???
Hello, I have written a small process, which should read a dmx-signal (seriell signal with special timings). THe whole thing is working realy good, but sometimes it makes things, which i hav...
19 years agoLarsen has a point here.
Take a look at the "check(dmx_in)". What is the source of the dmx_in signal? Is it clocked somewhere before entering the state machine? Or is it an external signal coming directly from a pin or from another clock domain? Sounds like a timing or meta-stability problem when the behaviour is erratic.
