18 years agoCyclone II I/O Output at Power Up!
Using a EP2C8F256C6 and found that during power up there is a 3.3V pulse coming out from the I/O pins. Pulse lasts for ~10ms. As I understand, during power up, pins should be tri-stated but I'...
18 years agoThe i/o are really tri-stated at power-up, reset, configuration and initialization (to be verified).
In cyclone II device, there are a weak pull-up resistors(~25kOhms) wich pull the pins high. See datasheet and "configuration handbook" Except for some pins : dev_oe which goes low (open drain) until the first data configuration frame comes. If you use dev_oe as an user I/O pin.
