10 years agoCyclone II FPGA Starter Kit - CSK SD Card Audio - Using GPIO
Extreme newbie question :( Does the provided FPGA configuration that comes with the starter disk (CSK_SD_Card_Audio) have the GPIO header(s) configured to be used? I'm not seeing any varia...
10 years agoSuch a configuration would use up a lot of FPGA resources. You typically see demos of one board feature at a time. Your board should have come with a CD containing the source for the demo projects. You can check there to see what features are enabled for a particular project. If you don't have the CD, you can download it from the Altera web site.
