18 years agoCyclone II and NIOS frustrations
I have an EP2C20 on a new board that I'm trying to debug, and am having very strange problems. I am using a USB Blaster. Initially, the Quartus programmer would download the configuration, but...
18 years agoI had a similar type problem with downloading via the USB Blaster. I finally found that I had a signal integrity problem on the TCK line. The signal had a slight "shelf" around the threshold that I only found after looking at it with a Ghz scope. If you look at the Cyclone II NIOS Dev. Kit you will notice a 10pf cap(C556) on the TCK line. After adding this capacitor( it needs to be adjacent to the TCK pin), my problem was resolved.
