12 years agocyclone ii and ddr sdram interfacing
hi, i am using cyclone ii ep2c50 484 pin package, i am interfacing ddr sdram to fpga. here for data fpga has dedicated pins but for address and controls it doesn't have any dedicated pins. can...
12 years agoI strongly recommend you look through the following document: external memory interface handbook volume 5 - section i. altmemphy design tutorials (http://www.altera.co.uk/literature/hb/external-memory/emi_tut_ddr.pdf).
This discusses in great depth connecting DDR memory to FPGAs. Yes, there are dedicated pins for the data. Pin selection for the control bus (address, cs, wr etc.) is a little more flexible. I recommend you put a design together and let the tools give you a pinout. You can either use this as is or make changes, each time confirming, with Quartus, that the pin changes you're making can be supported. Regards, Alex
