13 years agoCyclone II + NIOS design crashes with high IO pin drive strength
I have a commercial design for a Cyclone II FPGA which communicates with an external SDRAM chip. The FPGA contains a NIOS system designed in QSys, that run's its 'C' code from the external SDRAM. ...
13 years agoHigher I/O strength = fast edge transitions = more coupling to other traces and higher current requirements from the power supply.
It sounds like you have a layout issue on your new board, eg., traces routed too close to each other, or a clock missing a termination resistor. If the problem occurs with the JTAG interface, take a look at those signals with a scope. Perhaps there is a clock-like signal routed nearby that is coupling onto the JTAG signals. If the FPGA package is a TQFP, do the VCC pins have decoupling capacitors on the same side of the PCB as the FPGA, i.e., right next to the power pins? Cheers, Dave
