18 years agoCyclone II : Configuration through Embedded JTAG
Dear All, i am new to the FPGA world. I am using FPGA for signal processing. i have the *.rbf file. i want to load this file into FPGA SRAM.this the following step i m performing: ...
18 years agoI can't determine from the information you gave, if you are processing the *.rbf file correctly and using the right JTAG commands. Do you follow any Altera documented method? Most embedded systems I know, that are configuring the FPGA from a microcontroller or logic device are using PS or PP.
