17 years agocyclone ep1c20 flash
I use the ALTERA Cyclone Development Kit ep1c20F400C7 Question 1:how to see the result of the program or how I load my application in Flash Question 2: How to view & delete the contents of...
17 years agoIf you are designing system based on Nios II processor, you can use Nios II EDS to see results and in same application you will find flash programmer through which you can load your application in flash, also you can view flash content (in memory window) when you run Nios II application in debug mode
