16 years ago
cyclone 3 restricted fmax
at some point during my work I needed to use a higher frequency clock in Cyclone 3 (EP3C16) speedgrade -8 and thought of a 400 MHz clock. In the Cyclone 3 Handbook volume 2 table 1-19 it is specified 402 MHz for this core. However after running implementation TimeQuest reports an fmax of ~250 MHz with the mention that it is restricted to 238 MHz due to minimum period restriction (tmin).
Where did this tmin come from? I haven't seen it in the datasheet. Any hints?
    --- Quote Start ---
    P.P.S.: Or do you have a M9K-block connected to this clock? That has a fmax of 238MHz with -8 speedgrade.
    --- Quote End ---
    Yes, Quartus knows about the frequency, i constrained the PLL input and the 400 is inclk x 10. Duty cycle is 50%.
    There is a small altera fifo generated here (built around an M9K), i guess you're right. I should generate it in logic (size only 4x16). Hope it works!
    I think, I have seen similar things. My explanation for it was that some global clock networks have a lower fmax then others, but this is just a guess. Have you constrained your clock, so that the fitter knows that you want to achieve 400MHz?
    Thomas
    P.S.: I suppose you have not specified a duty-cycle for your clock different to 50%?
    Tricky,
    you haven't read my post carefully... I know about fmax and design but i have no idea why the 238 restricted fmax (second column in timequest->report fmax) is there... my understanding it should be 402 instead of 238... right?
    The fmax will come from your design.
    The datasheet fmax of 402MHz is the theoretical fmax. The actual fmax will depend on your design.
