17 years agoCyclone 3 problem: Holding nConfig low
I am having a really weird problem with a really simple board. Using an EP3C25E144C8N, active serial configuration mode with an EPCS16, MSEL[2:0] = 010. I can successfully erase and program the con...
17 years agoFvM, I was able to successfully mill a 1/16" hole through the PCB and attach a tiny wire to ground that pad...and it works now! :D
