18 years agoCyclone 3 migration from EPCS64 to EPCS128
Hello all,
In our design, we are using successfully the EP3C10 and EPCS64 configuration device (AS mode). We need to switch to the 128Mbit device (EPCS128); the FPGA fail to config in that case: the FPGA reads the flash status register, the flash electronic signature and then read the RBF header; it fails at this point. We know there is a difference in the way the flash electronic JEDEC signature is read (RES command not supported in 128Mbit device). How do we tell the Cylone III device to use the RD_ID command (read identification) instead of the RES command (read electronic signature)?14 Replies
So, can you confirm that you have been able to use the Spansion part successfully?
Looking for info on the 128 Mb device in my case. - Altera_Forum
--- Quote Start --- So, can you confirm that you have been able to use the Spansion part successfully? Looking for info on the 128 Mb device in my case. --- Quote End --- Yes, I can confirm - it works :) - Altera_Forum
--- Quote Start --- I have exactly problems with my custom board (fpga - EP2C20Q240), but i use M25P128 instead EPCS128 and ID also = 0xFF, but not 0x18 (as must be in EPCS128). Did you add additional CPLD chip on your board which generate respond with ID=0x12, am i right ?? Have you made this with EP2C20*. Thanks. --- Quote End --- Hi svale, I also want to use an M25P128. Is it a Micron device? Did it finally work on your board without Problems? Greets sim
