18 years agoCyclone 3 migration from EPCS64 to EPCS128
Hello all, In our design, we are using successfully the EP3C10 and EPCS64 configuration device (AS mode). We need to switch to the 128Mbit device (EPCS128); the FPGA fail to config in that case:...
18 years agoI have exactly problems with my custom board (fpga - EP2C20Q240), but i use M25P128 instead EPCS128 and ID also = 0xFF, but not 0x18 (as must be in EPCS128).
--- Quote Start --- Since the EPCS128 doesn't respond to Flash "Read Silicon ID" command (ID=0xFF), we did a patch with a CPLD that make the Flash respond to this command with ID=0x12 (EPCS4 ID) and the FPGA successfully configured (eureka!). [/LIST] --- Quote End --- Did you add additional CPLD chip on your board which generate respond with ID=0x12, am i right ?? Have you made this with EP2C20*. Thanks.
