12 years agoCyclone 3 E144 package getting hot and Cannot program the Cyclone using EPSC4 Chip
Thanks in advance, for any help you guys can provide . I'm trying to configure a Cyclone 3 (EP3C5E144) device using AS configuration mode. I'm currently using the EPCS4 chip for the AS mode configu...
12 years ago --- Quote Start --- The problem is solved now. --- Quote End --- Great! --- Quote Start --- It was very unclear how Altera called different power pins. I had used an altera Max II before and the unmarked power pin in the Pin Layout represents a 3.3 V. But in this case when i printed out a copy of the pin layout from Quartus the unmarked power pin represents VCCP/VCCR/VCCT. I thought that was meant for 3.3 V for the chip main power supply. So after checking the pin names from Quartus Pin Assignments, there it shows me to be VCCD_PLL, which is meant to be connected to 1.2 V and not 3.3 V. Therefore fixed my problem, I also added decoupling caps to make sure that my power supplies have monotonic ramps. Everything works as its suppose to now. I hope this help any potential users of the Cyclone 3, to be careful about power pins. Altera documentation is horrible at their nomenclatures. --- Quote End --- I haven't seen any problem with their pin assignments documentation. For example, the Cyclone III handbook page: http://www.altera.com/literature/lit-cyc3.jsp Has a link at the top to the "Pin Connections" guidelines http://www.altera.com/literature/lit-dpcg.jsp and the "Device Pinouts" http://www.altera.com/literature/lit-dp.jsp?category=cyc%203&showspreadsheet=y These two documents have everything you need regarding power pins. Cheers, Dave
