12 years agoCyclone 3 E144 package getting hot and Cannot program the Cyclone using EPSC4 Chip
Thanks in advance, for any help you guys can provide . I'm trying to configure a Cyclone 3 (EP3C5E144) device using AS configuration mode. I'm currently using the EPCS4 chip for the AS mode configu...
12 years ago --- Quote Start --- I've attached the diagram that I've used for my connections. --- Quote End --- Right, this is what you'd explained above. --- Quote Start --- If you need any more specific information, I will gladly provide it. --- Quote End --- Post your schematic of your board. Whatever you have done to make the chip get hot may be obvious from that. Cheers, Dave
