12 years agocyclone 3 and odd pin behavior
Using EP3C40F324I7N andEPCS16 in 'jic' setup. 'appears' only one pin, outputting a clock, D7, when programmed by the EPCS16, outputs a 'high' instead of a clock. (as apposed to low for un-assigned pi...
12 years agoYou've confused me now....:confused:
--- Quote Start --- drill out the via feeding that pin and then patch in a clock from another source --- Quote End --- I thought we were discussing an FPGA pin (D7) configured as an output? Configuring a pin as an input (providing there is no other load/drive on the net it's attached to) may well result in it going high thanks to internal pull-ups. In the FPGA's non-configured state it may well also appear high for the same reason. If it drops to zero when you configure it with a .sof image, then either a) you've specified in your design for it to drive low; or b) you've not assigned a function to that pin but told Quartus to reserve all unused pins: 'As output driving ground', as specified in the project's Device and Pin Options. Is this all moving away from your original issue? Regards, Alex
