12 years agocyclone 3 and odd pin behavior
Using EP3C40F324I7N andEPCS16 in 'jic' setup. 'appears' only one pin, outputting a clock, D7, when programmed by the EPCS16, outputs a 'high' instead of a clock. (as apposed to low for un-assigned pi...
12 years ago --- Quote Start --- How are your MSEL pins strapped? Are they configured for AS (Active Serial) configuration? You won't get a clock out of the FPGA's DCLK pin (to drive the EPCS) unless they are configured correctly. In that device pin D7 is a general purpose I/O pin. You're not expecting it to be DCLK, are you? Regards, Alex --- Quote End --- Left out, the rest of the chip appears to work. getting expected results from other outputs.
