18 years agoCyclone 2 + MLVDS transciever = PLL problem?
Hi We are using a NIOS2 processor and some VHDL code inside a Cyclone 2 240 pin package. Connected to the FPGA are 2 SRAM chips, EPCS16 and a couple of MLVDS transceivers, namely MLVD080 and MLVD...
18 years ago --- Quote Start --- Hi Milosd.. Sorry for the confusion.. :( My question is, is pin 92 on your cyclone II the same point as the clock pins on your sram? If you can send me a diagram, or a brief schematic of your system, that will be very helpfull.. Thanks you very much for replying --- Quote End --- Hmm I think you have a different RAM in mind... We are using Static RAM, meaning he doesn't require any clocks for operation since everything is tied to enable pins (write, read...) See the schematic attached.
