18 years agoCyclone 2 + MLVDS transciever = PLL problem?
Hi We are using a NIOS2 processor and some VHDL code inside a Cyclone 2 240 pin package. Connected to the FPGA are 2 SRAM chips, EPCS16 and a couple of MLVDS transceivers, namely MLVD080 and MLVD...
18 years ago --- Quote Start --- Hi "If the system is configured to run directly from the input clock 32.768MHz on pin 92 then the system runs fine (NIOS and VHDL)". how did you get the phase shift between the nios processor and the sram if u use the input clock? Thanks --- Quote End --- We let the NIOS take care of that, just add the IDT71V416 SRAM component (avalon slave) and that's it, just take care when connecting pins for byte enable and current limits if they are close and no resistors present on the lines :) works every time so far :)
