ADTL_belveera
4 years agoCyclone 10GX FPGA device 10CX105YF672I5G - Parallel CFI Flash connection pinouts
We are using the Cyclone 10GX FPGA device 10CX105YF672I5G along with Micron make DDR3L device MT41K128M16JT-125 and Spansion make 16-bit NIOS compatible CFI Flash device S29GL256P10TFI010 in our de...
YuanLi_S_Intel
4 years agoConnection is depending on the configuration scheme you choose. Since you are using CFI flash, the configuration scheme should be passive configuration scheme. You may refer to our pin connection guidelines for the connection:
