EDing
7 years agoCyclone 10, Passive Serial configuration Issues
We are using a Microcontroller to do this. We tested the programming software of the MCU on a Cyclone IV FPGA. I’m finding this was very much easier to do. There are different MSEL schemes for Pass...
EDing
7 years ago
Schematic images attached for FPGA Passive Serial
EDing
7 years agoHi Nooraini,
Have you got a chance to check the schematic? Here are more information:
The Voltage Level translators are from TI. TXS0104 and TXB0104. The TXB0104 is used only on DCLK and DATA0, because is higher speed.
TXB0104 is used for nSTATUS nCONFIG CFG_DONE and INIT_DONE
The inputs that are no connects, that we are questioning are:
CLKUSR is a no connect, will any of the high speed interfaces work if we do not provide a clock to CLKUSR?
nIO_PULLUP, DEV_CLR, and DEV_OE are also no-connects, hope they are not critical.
Thanks!
