Cyclone 10, Passive Serial configuration Issues
Hi Eding,
Can you provide your schematic for me to check the dedicated configuration pin connection? You don't need to provide the full schematic, you can just provide the schematic that contains the dedicated configuration pin connection.
Nooraini
- EDing7 years ago
Schematic images attached for FPGA Passive Serial
- EDing7 years ago
Hi Nooraini,
Have you got a chance to check the schematic? Here are more information:
The Voltage Level translators are from TI. TXS0104 and TXB0104. The TXB0104 is used only on DCLK and DATA0, because is higher speed.
TXB0104 is used for nSTATUS nCONFIG CFG_DONE and INIT_DONE
The inputs that are no connects, that we are questioning are:
CLKUSR is a no connect, will any of the high speed interfaces work if we do not provide a clock to CLKUSR?
nIO_PULLUP, DEV_CLR, and DEV_OE are also no-connects, hope they are not critical.
Thanks!
