BCrowell
2 years agoCyclone 10 LP Remote Update Simulation
I am trying to figure out the details on the remote update so I downloaded the example project (Cyclone 10 LP Remote System Upgrade Design Example) and set up a simulation to run rather than just use...
BCrowell
2 years agoAiman,
Thanks for this info. Do you know how the remote update logic obtains the data for those registers? Does it have to read the config flash memory to obtain the register data? Is there a way to simulate that process?
What registers could I read from in the simulation and get a valid response from? What I am trying to achieve is a baseline for my factory configuration when it comes time to set that up and control the register values to initiate the proper loading of the application configuration.
Brad
