sambesse
2 years agoCyclone 10 LP PLL frequency far too low
Hello, I am working on a Cyclone 10 lp problem using an internal PLL. I'm using the above AHDL code to configure it. The expected output is 245Mhz, since it's a 30.72MHz input and a mu...
- 2 years agoHi,
the small differences is frequency are obvious, you should be able to provide consistent values. However none of the quoted warnings is related to a fundamental problem that would prevent PLL function.
Some questions.
What's the reference clock source?
Is it a known working development board or custom design? In the latter case, are you sure that all hardware requirements, e.g. connection of PLL supply pins are met?
FvM
2 years agoHi,
PLL parameters looks right. If you are not familiar with PLL setup, you can also implement altpll from IP catalog.
I would probably add locked output to monitor correct PLL operation.
Most likely reason to ge a very low output frequency is that PLL gets no valid input clock, either wrong pin connected or inappropriate logic level.
