Cyclone 10 LP GND pins internally connected?
- 2 years ago
Yes, you are correct. As per my understanding, the GND pins are not connected internally as per in the Pin Connection Guidelines of Cyclone 10 LP, it mentioned to connect all the GND pins to the ground plane.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683137/current/supply-pins.html
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
It will be appreciated if you can fill the evaluation survey based on my support to your question.
Thanks a lot!
seriously I don't understand the original post. It says "I realized that the GND are connected to each other" and continuous asking "Is this correct that these pins are not connected internally?" In my understanding, the statements are contradictory.
- stomat2 years ago
thanks for your reply. I made a mistake in my original post, sorry for that. I wrote " I removed the FPGA from the pcb for measuring purposes and I realized that the GND are connected to each other. " but it should have been "I removed the FPGA from the pcb for measuring purposes and I realized that the GND pins are NOT connected to each other. ". I hope my question is now clear.
