stomat
2 years agoCyclone 10 LP GND pins internally connected?
I have design with a 10CL006YE144I7G which works fine in hundreds of devices but in few number of devices the FPGA stopped loading the configuration from the flash. I removed the FPGA from the pcb fo...
- 2 years ago
Yes, you are correct. As per my understanding, the GND pins are not connected internally as per in the Pin Connection Guidelines of Cyclone 10 LP, it mentioned to connect all the GND pins to the ground plane.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683137/current/supply-pins.html
AqidAyman_Altera
2 years agoYes, you are correct. As per my understanding, the GND pins are not connected internally as per in the Pin Connection Guidelines of Cyclone 10 LP, it mentioned to connect all the GND pins to the ground plane.
Reference:
