Cyclone 10 GX Transceiver Speed
On the Cyclone 10 GX datasheet, it's mentioned that the maximum transceiver output clock frequency is 6.25 GHz. Does this mean that the only way to reach the maximum data rate (12.5Gbps) is to use double data rate?
Michael
Hi Michael,
As I understand it, you have some inquiries related to the max data rate supported by C10GX devices. For your information, the max data rate supported is 12.5Gbps. You may refer to the device datasheet -> "Transmitter and Receiver Data Rate Performance" for further details.
Regarding the 6.25GHz, I believe you are referring to the TX PLL max output frequency. For your information, the data rate in the XCVR is 2x of the PLL frequency. For example, if you are configuring the Native PHY to run 12.5Gbps, the ATX PLL connected to the Native PHY must be configured to have 6.25GHz output frequency.
Chee Pin
1 Reply
- CheepinC_altera
Hi Michael,
Chee Pin
