Sumanth
2 years agoCyclone 10 GX Remote Update IP triggers reconfiguration randomly for reset signal
I have generated a remote update IP for Cyclone 10 GX with Flash combination MT25QU01G with Quartus Prime Pro 20.4 tool. If reset signal is sent to remote update IP, I am observing some strange beh...
FakhrulA_altera
2 years agoHi Sumanth,
Here are the key points to focus on for addressing the intermittent reconfiguration issue:
State Machine and Control Logic:
- Ensure the reset signal (RU_CONFIG) is properly de-asserted.
- Verify that the state machine transitions correctly to initiate reconfiguration.
Timing and Signal Integrity:
- Confirm that the reset signal timing meets the required specifications to avoid glitches or noise.
- Use an oscilloscope to check that the reset signal is clean and meets timing requirements.
By focusing on these aspects, you can address the root cause of the intermittent reconfiguration issue effectively. Refer to Intel® Cyclone® 10 GX user guide for more details.
Fakhrul
