13 years agoCYCLON IV GX - ALTGX Won't recieve any valid data
Hello I'm new in the forum, seems like very nice one me and my partner working on a final project for the university engineering degree. We have designed and manufactured two printed circu...
13 years ago --- Quote Start --- I was thinking we short the the pads and cut the traces near the the old termination resistor and place the caps there, might that help? --- Quote End --- Yes, if you can create a nice transmission-line like environment for the coupling capacitors, then it should work at higher frequency. Cutting the differential traces, scraping off the solder-mask, and soldering 0102 or 0204 or 0402 capacitors in-line with the old traces would result in the least impact. Try not to short the differential signals together though :) Cheers, Dave
