Custom linux image build failure for Arri10 SoC development kit
I am following the below documentation to build my custom Linux image for Arria10 SoC development kit. While building Yocto Rootfs, I am facing oe_runmake error. I have attached the log as well.
This is happening in the build process while compiling linux-socfpga-6.6+git package.
I tried below steps as well
step-1: bitbake -c cleanall linux-socfpga
step-2: bitbake linux-socfpga
But at step-2, again same issues.
Any help would be appreciated.
Sai
- tehjingy_Altera
Hi
Jingyang, Teh
- tehjingy_Altera
Hi
Just to follow up, are you able to boot the generated rootfs?
Jingyang, Teh
- tehjingy_Altera
Hi
Sorry for the late reply.
Got some problem with my laptop recently.
I just notice I did not attached my screenshot in my previous comment and have attached it.
For the sdcard creation you will need to use the "core-image-minimal-arria10.rootfs.tar.gz".
Jingyang, Teh
- sgannava
Hi Jingyang,
I am exactly following the same as mentioned in the documenatation. I am getting aforementioned error.
I have also tried by changing the size of all the partitions, but still same error, but I can see the image built. But when I see the disk partition, I culd not see the FAT32 partition.
As I said, in previous reply, "I assumed core-image-minimal-arria10.rootfs.tar.gz as core-image-minimal-arria10.tar.gz and proceeded further for creating an SD image" Could that be the problem?
Sai
- tehjingy_Altera
Hi
After I run the Yocto build for for the langdale branch the rootfs package is in the path below:
What is the full command that you used to created the sd card image?
Are all the required files in the folder for creation and is it the same as the command in the how-to?
cd $TOP_FOLDER/sd_card
sudo python3 ./make_sdimage_p3.py -f \
-P u-boot-splx4.sfp,num=3,format=raw,size=10M,type=A2 \
-P sdfs/*,num=1,format=fat32,size=32M \
-P rootfs/*,num=2,format=ext3,size=32M \
-s 80M \
-n sdcard_a10.img
Jingyang, Teh
- sgannava
Hi Jingyang,
Thanks for your response.
Are you able to see core-image-minimal-arria10.tar.gz in the specified directory? Becuase I am not able to see that if I built rootfs using nanbield branch?
FYI, I am able to build using nanbield branch only by removing linux-socfpga_6.6.bb file. But I cannot see core-image-minimal-arria10.tar.gz as mentioned in the documentation
So, I assumed core-image-minimal-arria10.rootfs.tar.gz as core-image-minimal-arria10.tar.gz and proceeded further for creating an SD image. But while, creating SD image, I see the below error. But surprisingly, I can see the sdcard_a10.img file built with 80MB size. However this is not booting the board. Kindly, look into this as it is blocking my work.
info: creating the image sdcard_a10.img
image removed
info: creating the partition table
image_name set to sdcard_a10.img
Partition return code [ 0 ]
now delete loopback
info: processing partitions...
partition #3...
do_partition entry
partition #1...
do_partition entry
error: format: failed. Return code=1params=['-F 32', '-I'], cmd=mkfs.vfat
stdout=mkfs.fat 4.2
Bad FAT type : 32stderr=Usage: mkfs.vfat [OPTIONS] TARGET [BLOCKS]
Create FAT filesystem in TARGET, which can be a block device or file. Use only
up to BLOCKS 1024 byte blocks if specified. With the -C option, file TARGET will be
created with a size of 1024 bytes times BLOCKS, which must be specified.Options:
-a Disable alignment of data structures
-A Toggle Atari variant of the filesystem
-b SECTOR Select SECTOR as location of the FAT32 backup boot sector
-c Check device for bad blocks before creating the filesystem
-C Create file TARGET then create filesystem in it
-D NUMBER Write BIOS drive number NUMBER to boot sector
-f COUNT Create COUNT file allocation tables
-F SIZE Select FAT size SIZE (12, 16 or 32)
-g GEOM Select disk geometry: heads/sectors_per_track
-h NUMBER Write hidden sectors NUMBER to boot sector
-i VOLID Set volume ID to VOLID (a 32 bit hexadecimal number)
-I Ignore and disable safety checks
-l FILENAME Read bad blocks list from FILENAMEThanks
Sai
- tehjingy_Altera
Hi
Sorry for the slow update.
I tried out the latest flow and found that I am facing the same error on my end.
However I tried out the older flow which checks out a different branch ("Langdale")
This is working on my end.
For the time being could you try the command below to build the rootfs:
cd $ROOTFS_TOP
rm -rf a10 && mkdir a10 && cd a10
git clone -b langdale https://git.yoctoproject.org/poky
git clone -b langdale https://git.yoctoproject.org/meta-intel-fpga
source poky/oe-init-build-env ./build
echo 'MACHINE = "arria10"' >> conf/local.conf
echo 'BBLAYERS += " ${TOPDIR}/../meta-intel-fpga "' >> conf/bblayers.conf
# Uncomment next line to add more packages to the image
# echo 'CORE_IMAGE_EXTRA_INSTALL += "openssh gdbserver"' >> conf/local.conf
bitbake core-image-minimal
ln -s $ROOTFS_TOP/a10/build/tmp/deploy/images/arria10/core-image-minimal-arria10.tar.gz $LINUX_BIN/a9/
Jingyang, Teh
- sgannava
Hi Jingyang,
Any update? Have you tried to reproduce the issue?
Sai
- tehjingy_Altera
Hi
Let me try out the linux image build flow and try to reproduce the issue that you are seeing.
Please give me sometime to reproduce this and get back to you latest by this week.
Jingyang, Teh
- sgannava
Hi Jingyang,
Without adding custom recipes
Following the steps mentioned in the documentation, I faced some errors and I have attached the screenshots
Error-1: linux-socfpga-6.6+git-r0 do_compile: oe_runmake failed
I have resolved this issue by removing linux-socfpga-6.6.bb file after cloning the repository
Issue-2: After running the bitbake core-image-minimal
In the documentation, it is mentioned that core-image-minimal-arria10.tar.gz will be generated under below path after running above bitbake command
But I cannot see the tarball with exact name. but instead, I could see core-image-minimal-arria10-rootfs.tar.gz. Hence, I used that and proceeded further. Finally I am able to created an .img file of size 84MB. When I load this onto board, I can see only blank screen on Putty. The conclusion is , without custom recipes also, booting not happening. I also checked that the shipping intel image is of size 1.02GB. I am not sure why the process is not creating the same.
General Questions here:
I have checked the SD partition after burning the SD with intel shipping image and image build from my side using Yocto. I can see the major difference in partition. I have attached then screenshots as well. Can I know why I am seeing such difference?
With Custom recipes
Error-1: I am getting the bitbake errors. I attached the screenshots with name recipe_bitbake_error1
Somehow, I overcome the error by
- Renaming u-boot-xlnx-scr.bbappend to u-boot-xlnx-scr.bb
- Renaming the petalinux-image-minimal.bbappend to core-image-minimal.bbappend
- Renaming libiio_%.bbappend to libiio_git.bb
- Added required license file also in layer.conf file
Error - 2:
But again, I have come up with another issue. Attached as withrecipe_bitbake_error2
I have tried cleaning the project as well and cleaning the particular script as well, but nothing happened
With Regards,
Sai
