10 years agocustom i2c
Just after a quick/general comment as I am a bit new to HDL. I was struggling to get much over 30kHz on my i2c connection because my code on my Nios II processor was not handling the interrupts...
10 years agoNormally I think 1.5k Resistors as pull-ups should be enough. Also your drive strength is already high enough.
You have three options to try: - change the pull ups to 1k and meassure again. Compare if the Signal is better or the same. Don't use less than 1k! - Can you change the slew-rate to 2? - Can you use a active '1' instead of 'Z' for bits which are really high on the bus. Use 'Z' for inactive, ACK and data-receive. I once had also written an custom I2C-Core and I used '1' for all active high Bits generated by the master. As I remember, my bus also shows this "shark-fins" on edges from '0' to 'z' but not from '0' to '1'.
