17 years agoCreating delay on an internal signal
I have an internal signal on a Cyclone II that I need to delay on the order of several nanoseconds. Best practices and omg-he's using-asynchronous-code aside, what would be the best way to do this? C...
17 years agoForum member Rysc has demonstrated, how to set delay by timing constraints:
http://www.alteraforum.com/forum/showthread.php?t=3068 A delay can also generated manually by inserting logic-cells with a keep attribute. With Cyclone III, 4 to 5 logic cells insert 1 ns delay.
