12 years agoCreate SignalTapII List File
Hi Dear all; when I capture my 8-bit digital output by Signaltap and right click in the white space and select the "Create signalTap II List File" a text file of data created but the problem is th...
12 years agoThanks for your reply; another question I have is that:
I implemented Sigma-Delta ADC on FPGA and my 8-bit digital output are @ 200 kS/s; However the input sampling frequency is 50MHz when I want to capture my 8-bit output by SignalTap, in signal configuration part, I was asked to enter the clk; The question is which value for clk should i choose?200Ks/s or 50 MHz? and when I captured the data the sample index start from -1024 to 7167 I wonder why it doesn't start from 0 to 8192? is it important? or I can consider the -1024 as first sample captured? the text file is as bellow Signal Legend: Key Signal Name 0 = DATA[0] 1 = DATA[1] 2 = DATA[2] 3 = DATA[3] 4 = DATA[4] 5 = DATA[5] 6 = DATA[6] 7 = DATA[7] Data Table: Signals-> 0 1 2 3 4 5 6 7 sample -1024 1 1 0 0 0 1 0 0 -1023 1 1 0 0 0 1 0 0 -1022 1 1 0 0 0 1 0 0 -1021 1 1 0 0 0 1 0 0 -1020 1 1 0 0 0 1 0 0 . . . 7165 0 0 1 0 1 1 0 0 7166 0 0 1 0 1 1 0 0 7167 0 0 1 0 1 1 0 0 Thank you
