17 years agoCPU instead of USB-Blaster
Moin, On my design i have a CyclonII (2C35), which normally gets its config from a EPCS16. Programming the EPCS16 can be done by USB-Blaster via the the 2C35. So far no problem. In additio...
17 years agoWhat you try to achieve involves undocumented steps. Programming default SFL image would the most easy and is documented, cause it means performing a FPGA configuration through JTAG from an embedded processor. The embedded JRunner code can do.
The more complicated action is JTAG indirect programming, in other words controlling the SFL through virtual JTAG protocol. Virtual JTAG protocol generally is documented in an application note, the SFL specific protocol part isn't explicitely documented and has to be extracted from the SFL HDL code. Finally you have to perform each step in EPCS programming separately, there's no intelligency built into the SFL design. For this reason, it's much easier to program an EPCS device at the AS interface directly, as cms mentioned. That's what most people do. Of course, if you didn't connect the interface in your design, you can try indirect JTAG programming. I'm sure, that it can work, but it involves a much higher effort.
