17 years agoCPU instead of USB-Blaster
Moin, On my design i have a CyclonII (2C35), which normally gets its config from a EPCS16. Programming the EPCS16 can be done by USB-Blaster via the the 2C35. So far no problem. In additio...
17 years agoMoin,
Yes, right - AN370 goes into the right direction, but lacks details :) Yes, i have a .jic file, which i want to put into the EPCS via JTAG and the FPGA. That's what i want to do. But : How exactly do i load e.g. the SFL Image into the FPGA? Which JTAG commands are necessary, (how) is communication between the SFL Image an the USB-Blaster (or in my Case: CPU) to load the contents for the EPCS if the SFL Image is in the FPGA up and running? Does there exist any available documentation? Cheers, WK
