17 years agoCPU instead of USB-Blaster
Moin, On my design i have a CyclonII (2C35), which normally gets its config from a EPCS16. Programming the EPCS16 can be done by USB-Blaster via the the 2C35. So far no problem. In additio...
17 years agoThe serial configuration device can be programmed in-system by an external microprocessor using SRunner.
The FPGA can program the serial configuration device in-system using the JTAG interface with the Serial FlashLoader. This solution allows you to indirectly program the serial configuration device using the same JTAG interface that is used to configure the FPGA. "AN 370: Using the Serial FlashLoader with the Quartus II Software."
