17 years agoCPU instead of USB-Blaster
Moin, On my design i have a CyclonII (2C35), which normally gets its config from a EPCS16. Programming the EPCS16 can be done by USB-Blaster via the the 2C35. So far no problem. In additio...
17 years agoMoin,
--- Quote Start --- I assume you don't program EPCS through Cyclone, you program it through the Active Serial which linked to both EPCS and FPGA. --- Quote End --- No, unfortunatelly i do not use Active Serial, but definitly JTAG Mode to program the EPCS through the FPGA. So afaik i'd have to load that "Factory Default SFL Image" first into the FPGA, start it and then somehow push my FPGA Config into that SFL Image - right? Cheers, WK
