12 years agoCPLD vs FPGA:
So Lets say I wish to analyse pixel streams ( uncompressed DVI) I HAVE A 1 SECOND/16 000 000 time time window, until the next pixel. Multiple 24 bit parallel RGB combinations activate cert...
12 years agoThe FPGA's are going to require multiple supply rails, but is the correct device for the job.
I suggest you look at one of the many development boards as a first step. See if you can find one that gives you the io functionality you desire. It sounds like a mid-sized Cyclone III should be plenty for you needs. If you think the DE0 board will work for you, that's a nice cheap board to play with and get use to FPGA's. Of course there's all kinds available. They also have a whole range of Cyclone IV and Cyclone V boards available. www.terasic.com If you need a CPU in the system as well, the SoCkit is a great way to go as well. Pete
