14 years agoCPLD VHDL problem
HI, I am trying to understand the operation of the following VHDL code. The cpld EPM2210 is attached to a processor bus (d0-d15 and A0-A15). When I do a double read 'word aligned' address rang...
14 years agoHere is the code I am trying to to get to work:
I am interested in the read condition when state_rd_fifo changes state: process(reset_n,clk,state_rd_fifo, proc_data(15 downto 0), proc_addr(15 downto 0), proc_cs2_n, proc_rw_n, state_rd_fifo) variable end_fifo_24_words : integer range 0 to 30 := 0; begin -------------------------------------------------------------------------------- -- main reset -------------------------------------------------------------------------------- if reset_n='0' then proc_data <= "ZZZZZZZZZZZZZZZZ"; state_rd_24bits <= idle_state; read_uart_24 <= '0'; fifo_enable_read <= '0'; fifo_enable_write <= '0'; end_fifo_24_words := 0; state_rd_fifo <= state1; -------------------------------------------------------------------------------- -- start decode chip select and decode address input with a WRITE -------------------------------------------------------------------------------- elsif rising_edge(clk) then if (proc_cs2_n='0' and proc_rw_n='0') then case proc_addr(15 downto 0) is when "0000000000001110" => case state_wr_24bits is when write_byte_1 => temp_word_24_0(23 downto 8) <= proc_data (15 downto 0); state_wr_24bits <= write_byte_2; when write_byte_2=> temp_word_24_1(23 downto 8) <= proc_data (15 downto 0); if(tx_ready_0 ='1') then -- now write the 24 bits to uart start_tx_0 <= '1'; tx_data_register_24bit_0 <= temp_word_24_1(23 downto 8) & temp_word_24_1(7 downto 0); tx_write0 <='1' ; state_wr_24bits <= write_byte_1; end if; end case; -------------------------------------------------------------------------------- -- start decode chip select and decode address input with a READ -------------------------------------------------------------------------------- elsif (proc_cs2_n='0' and proc_rw_n='1' ) then case proc_addr(15 downto 0) is when "0000000001010010" => proc_data (15 downto 0) <= X"2357"; when "0000000001010011" => proc_data (15 downto 0) <= X"5678"; when "0000000001010100" => proc_data (15 downto 0) <= X"eb67"; when "0000000001010101" => proc_data (15 downto 0) <= X"e8fd"; when "0000000001010110" => proc_data (15 downto 0) <= X"1ba5"; when "0000000001011000" => case state_rd_fifo is when state1 => proc_data (15 downto 0) <= X"1267"; --temp_word_24_0(23 downto 8); state_rd_fifo <= state2; when state2 => proc_data (15 downto 0) <= X"f23c"; --temp_word_24_0(23 downto 8); state_rd_fifo <= state1; when others => proc_data (15 downto 0) <= "ZZZZZZZZZZZZZZZZ"; end case; when "0000000001011010" => proc_data (15 downto 0) <= X"c438"; when others => proc_data (15 downto 0) <= "ZZZZZZZZZZZZZZZZ"; end case; end if; end process;
