18 years agoCPLD input question (by a primary user from china)
HI,Guys,I'm debuging EMP240T100。 I have set a signal "DONE" as input,and the pin doesn't connected to any device,but when I read it by DATA_BUS,it is '1', ps:DATA_BUS is a 16bits data bu...
18 years ago --- Quote Start --- Is 'Done' an input pin of the device? In that case, can you check if you have specified it correctly in the pin-options? And if it is a signal, then has there been any driver to that? --- Quote End --- 'Done' is just an input signal of the cpld,which is drivered by fpga. that's all. I haven't solve it yet. thanks for your reply!
