LFu001
7 years agoCpld epm7256 burning
Hi all, I need to burn cpld epm7256 and while using byteblaster usb and quartus 13 i can't access the device as it seems on the attached files, what does i miss? Thank you.
ak6dn
7 years agoThis is a CPLD device, which is EEPROM based, not SRAM based. It uses a .pof file for programming, NOT a .sof file.
The option you could try is a VERIFY of the programmed device versus a known .pof file, if you have one.
The only other option is to reprogram the CPLD with a .pof file and do a verify after programming to validate it programmed correctly.
There is no way to download a new temporary file to try it without completely reprogramming the device.
