15 years agoCounting the position of ones in a binary vector
I want to design a combinatorial circuit for an fpga which will count the position of ones in a 16 bit vector. eg1 if vector is 16'b0000_0000_0011_0101 then output should be 64'h0000_0000_0000_5...
15 years agono bugs, no hassle of spaghetti
additionally you can add clock or change indexing
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test is
port(
din : in std_logic_vector(0 to 15);
dout: out std_logic_vector(0 to 63)
end entity;
architecture a of test is
begin
process(din)
begin
for i in 0 to 15 loop
if din(i) = '0' then
dout(i*4 to i*4+3) <= "0000";
else
dout(i*4 to i*4+3) <= std_logic_vector(to_unsigned(i,4));
end if;
end loop;
end process;
end a;
