18 years agoCounter Power on Reset only
Is there anyway in Altera or Verilog code such that the counter gets reset to zero only on power ON. Please advise. (I am using EP2C35F672C6 "Cyclone II" within DE2 board)
18 years agoYou are right if you say it makes no sense to have a different behaviour.
I think most fpga's does not get 'reset' in the sense that you electrically pull a pin up or down. The 'reset' is just part of the configuration process. This way the synthesis of my little example follows the correct path : no difference, and the reset condition is used if any is specified. If howerver, no reset condition is given, you can specify it in an other way, using the initial condition. Stefaan
