18 years agoCounter Power on Reset only
Is there anyway in Altera or Verilog code such that the counter gets reset to zero only on power ON. Please advise. (I am using EP2C35F672C6 "Cyclone II" within DE2 board)
18 years agoThe register will have the power up condition as stated in the verilog design.
I found some instructions on how it can be done different in the quartus help :// Use a variable declaration assignment to set the power-up level
// of an inferred register.
reg q = 1'b1;
always@(posedge clk)
begin
q <= d;
end So it was time to do some tests : - when a reset condition is specified in the verilog code like this :
reg q;
always@(posedge clk or posedge reset)
begin
if (reset)
q <= 0;
else
q <= d;
end Then the reset condition (q <= 0 ) is used as startup value, regardless the specified initial condition. Even if I set "reg q = 1", the value for the register is zero after configuration. - when you don't specify a reset condition in the always block, the initial condition specified is used. However I didn't found a way to visualize the reset condition in the quartus environment (also not in the chip editor). Stefaan
