12 years agocounter design using sopc builder
Hi, I had created a new component counter and also its slave interface by writing the hdl code and then included as a component using new component wizard in sopc builder.I then exported the output e...
12 years agomy component is:
module counter(clk,clr,q); input clk,clr; output [7:0]q; reg [7:0]tmp; always @ (posedge clk or posedge clr) begin if(clr) tmp <= 8'b00000000; else tmp<=tmp+1'b1; end assign q=tmp; endmodule //slave interface module counter_slave_interface(clock,resetn,readdata,to_lights); input clock,resetn; output [7:0] readdata; output [7:0] to_lights; wire [7:0] to_reg,from_reg; counter my_instance(.clk(clock),.clr(resetn),.q(from_reg)); assign to_lights=from_reg; assign readdata=from_reg; endmodule whether i designed it correct or not?i need the exact c code to initialize the counter.thank you
