Count.binary template does not display on the 7 segmant
Hi, I am using quartus v13.1 and a DE2-115 board. I have a qsys niosII system compiled and programmed onto the board with no warnings or errors and a PIOs for the switches and all the seven segments which appears to have the correct pins assigned. When I try to run the count.binary template on eclipse, the system only displays the output on the nios console on screen. When I look at the c file the sections of the code related to the 7 segment and such are highlighted in grey and after using the debug tool I can confirm that these sections of code are not being executed. Also I have used copies of file examples and systems from tutorials of people who have uploaded their files. When I use their SOPCinfo file and select the count.binary template, the same issue occurs and the C code sections are still highlighted in grey. Also I am confused with the actual 0-ff counter. I would like it to modify it so instead of 0-ff it would simply be a 0-99 decimal counter but I cannot locate where this counting loop takes place. Any help would be greatly appreciated!
1 Reply
Appologies for the mistake, could a moderator please move this to the general nios forum
