14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- Using the tools becomes much simpler if you learn how to use the Tcl scripting language. The nice thing about scripts is you can write comments in them to remind yourself why you did things. Using the GUI is not as useful, as if you do not use the tools for a while, you forget how to use it. Look at the modelsim_example.zip file I referred you to earlier, and look at this tutorial: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial It has both Quartus and Modelsim Tcl scripts. Cheers, Dave --- Quote End --- Downloaded, i'll take a look as i can and surelly if i get a job on VHDL, ayway, the next year i'll degree in electronics since in my university only two subjects change from telecommunications to electronics, which i did as optative subjects on of these ones was the one that teached me VHDL. So i'll keep visiting this forum surelly, and here i know there are kind persons to ask to in case of complicated doubts. Thank you!!!! See you.
