14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- I should not post my code is my final 5th year engineering project by obvius reasons i can't. Yes it is an easy project but i did not have more time for something bigger. --- Quote End --- Ok, post an example design that generates the same warning message. For example, multiple two fixed-point numbers together and see if that gives you the error. Alternatively, you can email me the files (my forum name is my email), and I will delete them once I we have synthesis and simulation working. This is not cheating, as I have no plans to help you fix your code. If there are errors in the code, I will provide hints on what to do. Cheers, Dave
