14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- Again, i don't know what a Tcl script is --- Quote End --- Then you are not "listening" to what I am trying to explain to you. A Tcl script is just a series of commands. You are using a Tcl script called PFC.tcl - where did it come from? --- Quote Start --- "You must also run the Tcl from the Quartus console. You do that by sourcing the file" This (if it is the Tcl script) returns nothing --- Quote End --- The Tcl script will do whatever you have written in it. If you have not written it to print messages, then of course it will not display anything in the console. --- Quote Start --- Yes i'm a useless engineer, but i'm trying to end my degree. --- Quote End --- Don't take it that way. You are an "inexperienced" engineer. However, if you expect anyone to help you now and in the future, when you ask for advice, you need to listen to it, and then formulate follow-on questions indicating what you have done, and what you have failed to understand. Cheers, Dave
