14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years agoI've changed it on all .vhdl, but unfortunatelly:
error (10481): vhdl use clause error at producten.vhd(3): design library "work" does not contain primary unit "fixed_package"error (10800): vhdl error at producten.vhd(3): selected name in use clause is not an expanded name
error (10481): vhdl use clause error at pack.vhd(9): design library "work" does not contain primary unit "fixed_package"
error (10800): vhdl error at pack.vhd(9): selected name in use clause is not an expanded name Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 316 megabytes Error: Processing ended: Thu Sep 13 20:40:22 2012 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error (293001): Quartus II Full Compilation was unsuccessful. 6 errors, 1 warning The target of the error is: use work.fixed_package.all;
